It is currently Thu Jun 19, 2025 11:50 pm
PostPosted: Wed Feb 01, 2006 1:02 am
Hesh, How about the little blades that Mario uses on his website ?
PostPosted: Wed Feb 01, 2006 1:07 am
i often use a chisel as a scraper.
i also have a range of small scrapers simply made by cutting up bigger scrapers, old back saw blades, etc. the hack saw is a wondrous invention!
PostPosted: Wed Feb 01, 2006 1:23 am
do your sharpening after since there will be burrs to clean up and perhaps some not so straight saw cuts to straighten up on the belt sander or file.
besides it will need to be resharpened from time to time.
PostPosted: Wed Feb 01, 2006 1:43 am
I use the box cutter or wall board trim knife razor blades and burnish a curl on it. They are much stiffer than single edge razor blades. I also round the edges to avoid dig-in.
First name: Roger
Last Name: Labbe
Razor blade (round the corners before using)
chisel
microscope slide
broken piece of glass
small corner hacksawed off from a commercial scraper
PostPosted: Wed Feb 01, 2006 5:08 am
Lee Valley has these miniature scrapers, might be handy:
http://www.leevalley.com/wood/page.aspx?c=2&p=32672&cat=1,31 0,41069&ap=1
I just used a chisel. Bob Gleason's got some nifty pictures on his website as well, re: using a heated chisel to get the finish off:
http://www.pegasusguitars.com/lacquer_removal_from_bridge_fo ot.htm
PostPosted: Thu Feb 02, 2006 11:03 pm
The latest issue of WOODWORK magazine has a couple of articles with cool ideas for making scrapers and knives.
Todd Rose
Ithaca, NY
PostPosted: Fri Feb 03, 2006 9:05 am
Hi Hesh,
I was looking around a while ago now and came across THIS page on the topic. It also has clear instructions with images.
Aaaammm, have you decided on a bridge shape as yet
Kimlarkim38751.7138078704
PostPosted: Fri Feb 03, 2006 9:18 am
Sorry Mattia, did not see that you had posted Bob's site first.
Oh well, great minds...
cron
